Originally Posted by nurvcom
2x512 adata 512 3200 ddr
i have overclocked a cpu but i never done memory how would i do that on a msi neo???
When you raise your FSB/DRAM Freq in a 1:1 ratio (stock) your ram automatically goes up with it.
When your system becomes unstable and you can boot anymore at a higher FSB speed, then you need to go into your ram settings raise the voltage .1v or .2v and relax your timings. Then you will most likely be able to keep going up in FSB/DRAM Freq (depending on the quality of your ram).
