1 - 11 of 11 Posts
recently i've upgraded to 7600gs from Radeon 9600XTG. is there any software to overclock my 7600gs for higher core or memory speed?<br>
please advise asap....thank you very much.
Use coolbits to start with.<br><br><a href="http://www.pcmech.com/show/optimize/896/" target="_blank">http://www.pcmech.com/show/optimize/896/</a>
<tr>
<div>
Originally Posted by <strong>Mootsfox</strong>
</div>
<div style="font-style:italic">Use coolbits to start with.<br />
<br />
<a href="http://www.pcmech.com/show/optimize/896/" target="_blank">http://www.pcmech.com/show/optimize/896/</a></div>
</td>
</tr>
</table>
</div>tenx again, i will try it out 1st...then let u know the result.<br />
btw, do i need any cooling hardware for my card after OC?<br />
currently i'm using Vantec fancard for my agp...previously for my 9600xt.
If the card ever goes over 100C you definitely would gain from better cooling. I idle at 52C, and load at like...eh 70C (just made that up lol).<br />
<br />
Graphics cards can get pretty hot (80C+) and be ok.
<tr>
<div>
Originally Posted by <strong>ouroboros1827</strong>
</div>
<div style="font-style:italic">If the card ever goes over 100C you definitely would gain from better cooling. I idle at 52C, and load at like...eh 70C (just made that up lol).<br />
<br />
Graphics cards can get pretty hot (80C+) and be ok.</div>
</td>
</tr>
</table>
</div>Don't let that 7600gs hit 100C. Ati X1900 series are the only cards I know of that won't fry at those temps. Once you past 75-80C on the stock cooler (which I doubt you will) grab a new one. Your temps should not increase too much just from clock increases, volt increases raise the temp a lot more.
I have a pny 7600gs 512mb agp and i'm still lern how to oc it, my old 6600 did a lil better, it think i might need a bigger psu. because on start up it say it lowers setting to prevent damage to card, but still at that it won't oc that far.
anyone else had this problem????
Getting a new PSU won't hurt.<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817341001" target="_blank">http://www.newegg.com/Product/Produc...82E16817341001</a>
Keirth when it does that it meens you have overclocked too much.
but i hardy oc it.
<tr>
<div>
Originally Posted by <strong>KEITHRH12</strong>
<a href="showthread.php?s=5bd08cb0a2becf66ff9a516b8d226d15&p=1352150#post1352150" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">I have a pny 7600gs 512mb agp and i'm still lern how to oc it, my old 6600 did a lil better, it think i might need a bigger psu. because on start up it say it lowers setting to prevent damage to card, but still at that it won't oc that far.</div>
</td>
</tr>
</table>
</div>Actually it is not a power supply problem, it's a power sentry warning that goes off because of the timings set on the card, most 7600gs' have this same problem.<br />
<br />
Don't waste the money on a new power supply, if you haven't modified it, contract PNY and RMA it till you get one that doesn't do it.<br />
<br />
I'm in the same boat problem is I installed an aftermarket heatsink on mine so i'm stuck with it.
1 - 11 of 11 Posts
