How to open EK block?
307 Views 4 Replies 5 Participants Last post by  microman
I want to clean the internals of an ek nb block but can't figure a way to open it up. Normal screw drivers don't work from what I've tried.
1 - 5 of 5 Posts
Normal screw drivers won't work on the screws used on the blocks. Go to your hardware store, take the block with you, and get a screw driver or bits that fits the bolts. Or perhaps you have one laying around...
Should be either
or
. Don't remember if it was hex or torx again - perhaps something else also?.... Anyways, get one that fits nicely or else it's easy to mess up the screw heads.
With the right screw drive or bits type you should be able to open the block.
Its an allen wrench head isnt it?
They look like allen heads to me to. But yeah take it to the hardware store with you, they may be metric, probably are.
didnt the block come with a key??? all the EK blocks ive bought have come with one.
1 - 5 of 5 Posts
