1 - 8 of 8 Posts
Try Coolbits. you should also be able to use ATI Tool for Nvidia or Rivatuner.<br><br>
Raise speeds in 5Mhz increments, first the Clock until it is unstable. Reset. Then the Memory speed in 5 Mhz increments until is is unstable. Make a note of the speeds that cause instability, lower them each by 5-7Mhz. Use these figures for your settings and test them.<br><br>
Try some games and make sure the temps are within tolerable limits.
<a href="http://www.softpedia.com/get/Tweak/Video-Tweak/GeForce-Overclocking-CoolBits-Reg.shtml" target="_blank">Here</a> is a link to where you can download coolbits. If you have passive cooling on that card, try to rig up a fan to it using zip ties, and you will get a much better OC.
Anyone know how i can get to coolbits in windows 7 after i put in the reg key?
<div class="quote-container"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Davayy</strong> <a href="/t/122244/how-to-overclock-my-graphic-card#post_16503953"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
what a way to bring back a dead thread.</div>
</div>
<br>
I haven't been on in a while, its pretty dead around here <img alt="frown.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/frown.gif"> wither way I still don't have a solution...
<div class="quote-container" data-huddler-embed="/t/122244/how-to-overclock-my-graphic-card#post_16506386" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Davayy</strong> <a href="/t/122244/how-to-overclock-my-graphic-card#post_16506386"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Use msi afterburner.</div>
</div>
<br>
agreed, MSI Afterburner was recomened to me over using AMD overdrive in CCC. <img alt="thumb.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/thumb.gif">
1 - 8 of 8 Posts
