Hey OCN
I was wondering if anyone knew a good way to protect the speakers, i have some problems where for example if someone turns on/off a light it will cause the speakers to crackle/pop, aside from that issue they are working perfectly well
They are connected to a surge protector, that has battery backup protection as well, but beyond that not sure what to do with them
there is nothing wrong with the House Wiring, although it may appear that way, everything works fine, only got issues with Speakers
