Staff note: This guide is potentially outdated as of 2019. Rigbuilder mostly behaves the same way today, but things have likely moved around a bit!
Hi, and welcome to OCN
First click "Rigbuilder" top right of this page!
Click "Create Rig"
Fill in what you have and keep clicking "Save and Continue"
Once done click your "user name"!
Scroll down to and click "Edit Signature Text"
Then drop down one of the "Show off stuff in your signature tabs" and select your Rig
Click "Submit"
All done
oh, and iirc your Rig might not show in your Sig straight away
And if you can't select your Rig from the drop down tabs, try a different browser!
Also, some have problems adding their Rig. And here's a work around that "Forde3654Eire" discovered
Quote: Originally Posted by Forde3654Eire
I would click on the drop-down box and choose my rig preset. However, when I click the "Preview" button, all I get is an error message saying "You can't preview an empty text box". So I typed in, for example, the name of my rig in the text box with the rig already chosen in the drop-down box and it worked. As long as that the main text box is not empty that's all tnat mattera I think.
Also, remember to use the Rep+ button on posts, if you find them helpful!
It's usually located bottom right of the posts! (although some sections are Rep free zone, like this one is) and staff can't be Rep'd either!
"What goes around comes around"
And remember, asking for rep+ is not allowed!
Click "Create Rig"
Click "Submit"
All done
