1 - 2 of 2 Posts
Download the ICH9R raid drivers and put them on a USB drive:
http://www.overclock.net/attachments...-bit-ich9r.zip
Then go into bios and set the SATA setting to RAID (in the main menu). Then reboot and press [Ctrl+I] to enter the RAID utility. Then create the array, add both the drives and set the stripe size to 128k. Then save and exit, go into bios again and go to the boot menu and set the RAID as the first drive in the drive priority setting. Then set the first the RAID as the first boot device. Save and exit. The with the Install DVD in, press F8 to enter the boot menu. Select the DVD drive to boot. Run the install and at the "Advance Options" select "Load drivers". Put the USB drive in and select browse. Then select the USB drive and click on the folder with the RAID drivers (make sure you have unzipped them to a folder). After that, install the OS as normal.
1 - 2 of 2 Posts
