1 - 20 of 30 Posts
Here is how you can skip right through your intros without having to press ESC, space, or wait for it to finish if you are some of the users who cannot skip them.
_________________________________________
Note:
I will be using the default location for the installation. That includes C:.
Also, you may have installed your game somewhere else. If so, locate your Crysis folder and find the Video folder.
*Instead of deleting the following files, you can also make a new folder and drag them in there just for safe keeping. Just in case if deleting the files interferes with any future updates/patches. Since there hasn't been any patches for Crysis yet, I do not know if deleting them will cause a problem when you install a patch.
-Full Retail Version
Navigate to: C:\\Program Files\\Electronic Arts\\Crytek\\Crysis SP Demo\\Game\\Localized\\Video
Delete or move the following files with the blue X.
-Demo
All credits goes to caos800.
Originally Posted by caos800 View Post
The way I did it was going to Program Files -> Electronic Arts -> Crytek -> Crysis SP Demo -> Game -> Localized -> Video & removing all the files that had trailer in the name including the one in the "English" folder.
Discussion Starter #4
AH~! Thanks a lot! They worked really well.
Discussion Starter #6
Unfortunately I can't seem to find the file for when you quit...
You can just ALT + F4 at that period.
Do you mind if I make this thread into a How to: Disable Crysis intro screen?
All credits goes toward you.
Discussion Starter #10
My first post has been edited.
I hope it helps you guys!
Crysis multiplayer demo??? where? pm me plz
It's the same as BF2/2142. Just create a new folder in the video folder and move them there.
It doesn't exist. There is a mulitplayer beta though.
Discussion Starter #15
Updates:
-Full version is added.
-Beta has been removed since it ended.
-Disable word on the topic name have been changed to remove.
Does the
-nointro
comment work in Crysis like it does in BioShock?
Or is the only way to disable the intro movies to rename the file types from .sfd to ._sfd like I did? (Or delete them of course.)
Nice job Tai
At least I don't have to wait so long now when restarting the game after the "save mission" bug locks me out whilst protecting Prophet
Rep+
Discussion Starter #20
Originally Posted by Xombie View Post
Does the
-nointro
I really don't know about the -nointro. I have never heard of it before.
Bump for your question.
1 - 20 of 30 Posts
