Thought I'd share a little command line fun I figured out this morning. Forwarning, this Will compleatly remove the msconfig>startup program entry from the startup list.
Example: Utorrent
Finding the entry and registry location
Verifying the registry program and location to to edit..
Deleting Utorrent from the starting when the OS loads.
Adding value back into the registry:
This is the command to add the registy entry back into the startup menu. Note: notice the " " quotes in the sting destination. This is required unlike when using regedit.exe.
Example: Utorrent
C:\\>wmic startup where caption="utorrent" list full
Caption=uTorrent
Command="C:\\Program Files\\uTorrent\\uTorrent.exe"
Description=uTorrent
Location=HKU\\S-1-5-21-1390067357-261478967-682003330-1003\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Run
SettingID=
User=LAPTOP\\scott
C:\\>reg query HKEY_USERS\\S-1-5-21-1390067357-261478967-682003330-1003\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Run\\ /s
! REG.EXE VERSION 3.0
ctfmon.exeREG_SZC:\\WINDOWS\\system32\\ctfmon.exe
uTorrentREG_SZ"C:\\Program Files\\uTorrent\\uTorrent.exe"
C:\\>reg delete HKEY_USERS\\S-1-5-21-1390067357-261478967-682003330-1003\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Run\\ /v utorrent
Delete the registry value <Y/N>? y
This opperation completed sucessfully
C:\\>reg add HKEY_USERS\\S-1-5-21-1390067357-261478967-682003330-1003\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Run /v uTorrent /t REG_SZ /d "C:\\Program Files\\uTorrent\\utorret.exe"
