1 - 2 of 2 Posts
The following steps will check and possibly repair corrupted NSF files.
> Open a command prompt and change the directory to your Lotus Notes program directory.
> Enter the command: nfixup.exe X:/.nsf (+enter)
This command initiates a general scan of the NSF file and tries to repair it when corrupted. After competion index the NSF file again with Intella. If you still have an issue indexing, continue with the following step.
> Enter the command: ncompact.exe X:/.nsf (+enter)
This command compacts the NSF file. After competion index the NSF file again with Intella. If you still have an issue indexing, continue with the following step.
> Enter the command: nupdall -r X:/.nsf (+enter)
This command rebuilds the entire NSF index.
Some actions from here:
Or:
NSF Viewer Tool
A must-have tool for quick and hassle-free Lotus Notes repair. The product combines the convenience of a step-by-step wizard with the power of professional data recovery tools.
For more information: http://www.nsf.viewertool.com/
1 - 2 of 2 Posts
