Someone needs to give bwg more access.
He got denied access. He asked, and was shot down faster a twinkie at weight watchers meeting.
Why the hell?
I think its because he would have to have access to the Moderator's admin CP, and they don't like sharing that with non-moderators.Originally Posted by Totally Dubbed
Why the hell?
You and him do so much for the folding community - why can't he have access to that?
It's not even a privilege more of a "responsibility" - it's embarrassing for the admins or whoever is in charge for denying him this access. It is also shameful that they are doing it - almost like not appreciating his work.
then make the man a "mod" then!
The reason is he would most likely gain access to the full Admin panel (the one used by Admin, Chipp, ENTERPRISE and The_Manual), as you can imagine there is a need to keep access to the full panel limited.Originally Posted by anubis1127
Why the hell?
Ah, thanks for clarifying. Its still pretty much what I thought, they don't want to give BWG access because in order to do so he would get access to a whole host of other areas not needed for awarding the badges.Originally Posted by Bitemarks and bloodstains
Even forum mods do not have access to the award page, senior mods do but we don't have access to the tool to correctly issue the badges.
maybe it should be split then?Originally Posted by Bitemarks and bloodstains
Like Totally Dubbed has said, I think it would be a huge step in efficiency if the awards authority were shifted to a more 'local' staff member. With all the changes to the website I'm sure the full Admin have enough on their hands. Plus, from what I can see, the vast majority of award badges are for Folding milestones, it would make sense that an editor/moderator closer to the Folding secton would be in charge.Originally Posted by Bitemarks and bloodstains
Exactly^
I concur, but I am sure you will agree, while it might require more effort then the end result would warrant, it would certainly help out the [email protected] masses.Originally Posted by fragamemnon
Rather it would depend on the architecture.
If Huddler doesn't allow for such flexibility in terms of access control, it can't be done. Or, to be more precise, the efforts put into doing this will outweigh by a wide margin the efforts needed to manually award badges.
I speak because I've collided with this problem on a platform for a custom built web-based catalogue I work with. It forced us to change the platform, and even those efforts (read: exporting, formatting, importing, stress- and proof-testing of millions of records, not over-exaggerating, with every other index holding different categories and sub-parameters) were less than the ones needed in order to remodel the old platform to allow for finer grained access control.
I speak because I've collided with this problem on a platform for a custom built web-based catalogue I work with. It forced us to change the platform, and even those efforts (read: exporting, formatting, importing, stress- and proof-testing of millions of records, not over-exaggerating, with every other index holding different categories and sub-parameters) were less than the ones needed in order to remodel the old platform to allow for finer grained access control.![]()
Done it hundreds of times on this platform, very easy to limit or extend access beyond the "Default" if you know what you are doing.Originally Posted by fragamemnon
