How to set up GX2 and [email protected]?
348 Views 6 Replies 3 Participants Last post by  MAD_J
Looking to set up a recently purchased gx2 for folding. Anyway when I try to open the systray client it says gpu is not supported. Is this because I just downloaded the latest nv drivers? Or because I used to have a 5870 in the machine?
1 - 7 of 7 Posts
Try cleaning/uninstalling out all the ATI drivers and install latest certified nVidia drivers.
http://www.overclock.net/overclock-n...a-folding.html
Do you have at least one of the cores working? Or is it just the second one thats giving errors.
I just got the first working but the second still says not supported
Ok then you need to extend your desktop. Your GX2 should have both DVI ports filled and extended to both. Basically once you connect a second monitor/dummy plug then you can fold on the second GX2 core.
If you dont have a second monitor heres how to make a dummy plug.
http://www.overclock.net/overclock-n...ummy-plug.html
Yea I have 2 inputs on my monitor so I connected and its working great. 11 k ppd
non oc'd
non oc'd
Nice to see you got it working!
1 - 7 of 7 Posts
