1 - 20 of 22 Posts
No, this is NOT an FAQ, but im confused about how i can setup raid. I just got a 80GB Western Digital 8MB Cache EIDE Hard drive, and i want to put it in raid with my 60Gig EIDE HD. Does this mean that my 80GB HD be 60Gigs and have 2mb of cache? And do i need to put any jumper settings on my drive? Thanks.<br><br>
-UberN00b
Nope, Need 2 indenticle HDD
Reactions: UberN00B
Try it...and see.<br>
No clocking done without trial and error
Discussion Starter #8
well, im going to go pick up another 80GB hard drive in a bit, but when i do, what would i need to do? I think i have a general idea but..<br><br>
1. Flash Bios<br>
2. Enter Raid Config<br>
3. Set up raid<br>
4. Install Windows<br>
5. Done?
The benifits of most simple raid arrays have been proven to be faster than a single sata drive but the increase isnt worth the cost .Unles you have important data that you cannot afford to lose then use raid 1 ..but other than that a good quality single drive will surffice.....Unless you are going to create a raid array with 10,000 rpm rapters then it does make a god difference
Discussion Starter #10
well i wanted to do it because RAID 0 makes a crazy diffrence in loading games and such... and ive never done it before... and all my information will be stored on flash drives, so its all trial and error.
<div>Originally Posted by <strong>UberN00B</strong></div>
<div style="font-style:italic;">well, im going to go pick up another 80GB hard drive in a bit, but when i do, what would i need to do? I think i have a general idea but..<br><br>
1. Flash Bios<br>
2. Enter Raid Config-<b>3</b><br>
3. Set up raid-<b>4</b><br>
4. Install Windows-<b>2</b><br>
5. Done?</div>
</td>
</tr></table></div>
Change that up<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Reactions: UberN00B
Discussion Starter #12
btw, if i did a raid with SATA, would it be better than EIDE? new to this kinda stuff, but im going to make an faq on how to setup raid after i figure all of this.
I,m not saying dont do it ...Good on yer have a go ...I use a raid setup and it is really only to load games faster. Call of duty tends to load a bout 3secs faster but thats all ...It is a nice feeling when you do finaly create your first raid array..Sata = 7200rpm EIDE 5200 rpm you tell me which is fastest
Discussion Starter #14
ok, so first i flash my bios so then the raid controller wont give me trouble..<br><br>
Second, I install windows? So i skip the RAID Section of my bios?<br><br>
Third, i go back into the raid configuration on my bios..?<br><br>
Fourth, inside the raid config, i set it up.... makes sense..<br><br>
And thats it?
<div style="font-style:italic;">wait, you can set up raid WITH EIDE, right?</div>
</td>
</tr></table></div>
Hell yes!!!!
<div style="font-style:italic;">btw, if i did a raid with SATA, would it be better than EIDE? new to this kinda stuff, but im going to make an faq on how to setup raid after i figure all of this.</div>
</td>
</tr></table></div>
SATA speeds are far greater than Parallel ATA whether it be 150 or 133...<br>
SCSI is the only faster than both<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Use that **** Ubern00b!!!<br>
Save the cake for a more serious upgrade homie!!!!<br>
All this new stuff coming out so fast...I'm contemplating taking back my 6800s to get another 80GB SATA and some store credit for real...
1 - 20 of 22 Posts
