1 - 4 of 4 Posts
So i have a U3011 monitor and a 2414Q monitor from Dell.
I've tried setting up both but i'm having big issues with this setup.
Basically, They won't scale individually, and if i want the 2414Q to look good ( scale it for 200%) the U3011 will scale as well ... and that sucks ... I just can't have both working with different scales.
Is there a way ( or can you point me out which options/ steps to do, since i just went to the display resolution dialog, and from there i changed the scale for each of the screens, but it didn't work the way i was hoping ).
Thank you all
Pedro.
Discussion Starter · #2 ·
Bump, anyone tried or had this problem when setting a 4k monitor along a "normal" one?
You can choose to scale only on one monitor.
This blogpost explain and show a bit of what's new with 8.1. I'm guessing you'll have to click "custom scaling options" or something, on the bottom. Have the entire post.
Thanks for the reply. Yeah, i tested that but the problem is that, now, my 2560x1600 is showing HUGE interface elements. :x
1 - 4 of 4 Posts
