How to setup an HTPC?
221 2
Hi so i have an old dell id like to use as an htpc up in my bedroom.
So... .how do i do it? anyone got any guides?
For like watching movies and stuff. from my main pc downstairs.
thanks!
1 - 3 of 3 Posts
Z-80 > i9
Get a copy of Windows Media Center edition, a TV tuner for it and a largeish hard drive.
Set those up, run media center, set it up, make sure everythings detected, etc, then it should all work easily.
If you can, run a ethernet wire to your room somehow it'd be best, that or a N draft router. You will need the speed to stream the videos from one pc to another. Otherwise just setup a network and transfer the files first, then watch.
Also considering it's a dell and knowing nothing else, I assume you need a video card. Go grab a cheap $30 or less 3450 or 4530 off newegg, setup and your set.
For software, unless you literally want a true htpc just run the windows on there now and watch videos on fullscreen.
1 - 3 of 3 Posts
