1 - 6 of 6 Posts
after updating to sp2 i got a login screen everytime i tried to access my PC, so heres a quick fix to the problem if your having it also(you need the Administrator password).
This is the login i encountered
So here the first thing you do to remove it.
Press Start Run
then enter "control userpasswords2"
and press OK
This next screen will then be presented to you
Untick the checked tickbox( Users Must Enter Username And Password To Use This Computer)
you will then be asked to enter the Administrator Password to apply the settings
once youve entered the password click ok and your all set .
Actually this is really good some times, I've been running with it for about 6 months now, and it's great if you're often at places where there's noobs (and can't steal your rig), just press windows+L when you go AFK and log in again.
Laziness FTW.
Yeah guys also if your machine used to login automatically and then one day stopped doing it then there is a simple fix. You need to right click my computer and go to manage and then from there to local user and groups and disable/delete the ASP.NET machine accounts and guest acccounts etc, because windows sees them and says oh there is other users on this computer so i better not log this guy in automatically if you get what i mean...
Cheers
1 - 6 of 6 Posts
