1 - 10 of 10 Posts
Simple - check with the company who certifies the PSU
Ecos Plug Load Solutions:
http://www.plugloadsolutions.com/80P...rSupplies.aspx
Hardware secrets recently (5/10/2010) did an article showing companies that have fake PSU 80PLUS certificates.
http://www.hardwaresecrets.com/artic...us-Badges/1054
So when buying a new PSU - double check with the above link that the model you want is definitetly certified with the 80PLUS certificate!
EDIT - WARNING 80PLUS cert doesn't mean the PSU you have is guaranteed amazing but it is worth checking to see if the one you are buying is as efficient as it makes out!
EDIT2 - Added USEFUL Excel spreadsheet with hyperlinks to PDF of each PSU
While you there at hardware secrets read the why 99 percent of psu reviews cant be trusted lol
Those links to some of the reviews on there funny as hell
Discussion Starter #6
Bump
WARNING - a 80 plus certificate does not mean your PSU is good!!!!
There are experts in OCN (example TwoCables, Shilka or Phaedrus2129) - they talk sense and only try to look after your PC and to help guide you in making the right decision. I suggest LISTEN and make an informed decision.
Good Luck!
Senior OCN Member
Originally Posted by Mitche01 View Post
Bump
There are experts in OCN (example TwoCable or Phaedrus2129) - they talk sense and only try to look after your PC and to help guide you in making the right decision. I suggest LISTEN and make an informed decision.
Good Luck!
What i dont count?
Joke aside i have always said 80 plus is not something you sould base your buy on
I know just that both does better and worse then its 80 plus rating
Senior OCN Member
Ego boosted...
Was a joke i dont think i am that known a user
But back on topic did you know that the Raidmax AE is overrated it really cant do 80 plus gold
If we look at the other end both the NZXT HALE 90 V1 and the Cooler Master V are rated 80 plus gold but can do 80 plus platinum
1 - 10 of 10 Posts
