1 - 11 of 11 Posts
Hey all!
Just a quick Q. How do i know if my raid 0 is working correctly. Ive followed the instructions as per mobo manual, installed all the drivers from a floppy. When i get to install vista, the two 320gb drives come up as one 640gb drive.
There are the symptoms... diagnose!
Discussion Starter #4
Originally Posted by maddux
you answered your own question grats...
yes its working.
But i thought that the drives were ment to show up as a single 320 gb, not a single 640gb? Isnt that the logic of raid 0? I thought all data was duplicated to improve access times....
Discussion Starter #6
Originally Posted by alwaysAMD
no, it is actually split up between drives.
So its like this then?
Filex is installed and split into so many parts (2)
each part is on both of the drives?
If you setup RAID 1 it would show up as one single 320Gb drive. RAID 0 is stripped across the drives, RAID 1 mirrors the drives.
Expand Always in Always
^^Correct,no fault tolerance with raid 0.Raid 1 you'll be covered.
thats why you get a large 3rd drive for weekly backups. Which is what I'm doing currently and have done with all my rigs
Old Timers Unite
exactly what I'm doing as well. One 500gb external is what I have and just move all my important crap over to it every couple of days in case raid bites the dust.
1 - 11 of 11 Posts
