When we look at computer specs, we can tell which parts are better for certain things. Likewise, we even go further to the manufacturing processors/components to tell which one would do a better job over the other.
Can you do this with headphones too? What can you look for to determine which ones are better then others based on spec and reviews alone? A lot of the time it is all perception and tastes on the sound itself. But are there things that you can look that guarantee you to buy a certain headphone?
I did this test where it went from 10-200Hz. I was able to hear half-way between 10-20 and all the way up to 200Hz. By my understanding, the human ear can only hear 20Hz-20KHz but it seems that you can actually (in my case anyways) hear sounds under the 20Hz range. Would a 6-24'000Hz headphones have the potential of making much richer basses then say a 20-20'000Hz rated phones?
Now I guess you can't rate specs alone, there is also the materials, design, etc. Quality of the parts, etc., even your own ear to consider. But is there a way to tell ones apart so that when you talk to someone inexperienced to the product, you can inform them in some way to help them pick good phones compared to the crappier ones?
