1 - 4 of 4 Posts
Hey guys these are my specs, if you could please help me update and overclock my pc
Board: ASUSTeK Computer INC. A7N8X2.0 REV 2.xx
Bus Clock: 100 megahertz
BIOS: Phoenix Technologies, LTD ASUS A7N8X2.0 Deluxe ACPI BIOS Rev 1005 05/14/2003
go to the asus website and see if there is a bios update for your motherboard... if there is follow the directions to update the bios... and for overclocking read though this guide to get you started... then if you have further questions post back and let us know what u need help with... good luck
i downloaded the bios driver, it was called awdflash and when i clicked the exe it comes up with a black window then goes away.
i dont even know if it was an update or if i need it.
when i go in my bios i dont see anything about a multiplier or nothing.
hey, guys, my CRT is just staying on standbye, after i messed with a few things on BIOS. and i cant even change them back
any way to fix this
thanks-
Clear the CMOS.
1. Remove power to PS
2. Set jumper to CLear BIOS/CMOS and wait 10 seconds.
3. Return jumper to default.
4. plug in power to PS, reboot.
1 - 4 of 4 Posts
