1 - 7 of 7 Posts
Here's what it looks like. Is it worth using?
Stupid question but aren't some 3pin fans led?
No idea if they are any good or not, but I wouldn't use them.
Having independent power for LED means lighting doesn't change brightness every time fan changes speed. ;)
Discussion Starter #6
Can I just use the 3pin without using the LED?
Yes. Even if the 2-pin isn't lights, using the 3-pin should run the fan with no problems.
1 - 7 of 7 Posts
