1 - 2 of 2 Posts
Hi and welcome to the forum.If you want you can go to the volt mod's section.In there is some guides and information.If you volt mod a card before then you can use the volt mod that the people use in the 7900GT.Is all the same volt mod.Or take a look here check the last post and open the link is all the same information you need.Good luck.http://www.xtremesystems.org/forums/...ghlight=7950gt.Also maybe is better move this thread to the volt mod section.You want to post in the rigth section like that the people here can help you better.
1 - 2 of 2 Posts
