How would I overclock my Celeron?
390 3
im new to overclocking and i have a celeron =\\
i dont see any over clock guidesfor the celeron... anyways.. i have the AOpen AX4SG-UN motherboard and a intel celeron socket 478 3.06ghz cpu
what should i set my fsb , power and ram to..
btw i have ddr333 ram 2x 512mb
how would i go about overclocking this.. there are no guides for celerons yet!!!
~rabies
THANKS FOR THE HELP ^,^
1 - 4 of 4 Posts
Just read the Intel overclocking guide linked in my signature. That applies to Celerons as well as Pentiums.
all overclocking are basicaly the same... you go to bios and raise up a little your fsb... then check if your computer is stable... also check your temps... if everything's cool... raise up again.. you can do that untill you think you should stop... or when your CPu starts to be unstable or to hot... then you should downgrade the fsb...
1 - 4 of 4 Posts
