1 - 10 of 10 Posts
I have just nipped into town and brought this<br><br><a href="http://www.thecoolingshop.com/product_info.php/manufacturers_id/3/products_id/1442" target="_blank">http://www.thecoolingshop.com/produc...oducts_id/1442</a><br><br>
Will this cool my athlon 4400 down?<br><br>
Thanks for any advice given
It will cool it down but its not the best cpu cooler <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue">
Greetings,<br><br>
Seems small (80mm fan). Are you constricted by case size? Maybe consider the same style, but in a 120mm size. 120mm fans are far more efficient in CFM and dBa than 80's. I am sure that there is an exception to that, but probably rare.<br><br><a href="http://www.thecoolingshop.com/index.php/cPath/98_2_209" target="_blank">http://www.thecoolingshop.com/index.php/cPath/98_2_209</a><br><br>
Don't know what your budget is, but the Scythe's are good. The Zalman is also decent.
Discussion Starter #4
Iv already brought this one. It was the best in the shop so I had this one, I thought that I could upgrade the 80mm fan and put a better one on and this will make it better. Im not restricted in space
If space permits get a 80mm to 120mm adapter and achieve some great cooling that way.<br><br>
pink
<tr>
<div>
Originally Posted by <strong>ConteoAMD</strong>
</div>
<div style="font-style:italic">I have just installed it, and it speed fan which is my cpu temp? is it the core?</div>
</td>
</tr>
</table>
</div>Yeah, or sometimes its called the CPU Diode.
post a screen shot of speedfan. What I always recommend you do is write the temps down and reference them in the bios.<br />
<br />
pink
Discussion Starter #10
<a href="http://www.overclock.net/amd-cpus/122913-temps-ok.html" target="_blank">http://www.overclock.net/amd-cpus/122913-temps-ok.html</a><br />
<br />
thanks
1 - 10 of 10 Posts
