1 - 7 of 7 Posts
SNERP!!!
It really depends on what you want to put in it and where you want to install it. I would first figure out my watercooling setup and then we can help you from there.
im definately gonna be cooling my cpu and gpu is watercooling sli'd 7800's a problem ?? anyway im probably gonna keep it pretty basic i just want something better than air that does its job im gonna follow a guide a user posted on here i was just wondering for watercooling with everything most likely out of my case. if this case would perform good
SNERP!!!
SLI cooling is easy. It's just hooked up a little bit different.
That case should work. It's normally just a matter of what you want in a case and the room for what you want to put in it, but if you are going to put your rad outside your case it isn't going to be a problem. Read some reviews on it and see what the owners think of it. There isn't a case that you couldn't make work for WCing.
Almost any case will accept w/c but a Coolermaster Stacker or Antec p180 would make a good choice considering what your spending on the rest of the setup
1 - 7 of 7 Posts
