GeForce 7, 8, 9 & 200 Series cards
This works for 4xx cards also but you have to use nvflash 5.95 LINK...
First some cards have 256mb and 512mb make sure get the correct BIOS, you can cross flash cards like using a BFG BIOS on a eVGA it works some people do it As long as both cards are the same like 8800GTS & 8800GTS, but I prefer to use eVGA BIOS on a eVGA card ECT.
I've only ever had one bad flash when flashing a FX59
00GS to a FX59
50ULTRA but I had a backup and flashed it back.
1. Download the correct BIO's file you need here
NVIDIA BIOS LINK
2. After it's downloaded Rename this file to 1.rom
3. Download this program nvFlash v5.38
nvFlash LINK
4. Unzip nvFlash v5.38 create a folder on your desktop paste all of it in the folder.
5. Install a floppy in my computer right click it format and reformat it for MSDOS then open it.
6. open the folder with the
nvFlash,
cwsdpmi and the new bios
1.rom copy and paste them to the floppy, now the floppy should look like this,
7. Restart the computer with the floppy in.
8. Making a backup once you get to MSDOS and see the {A:\\} prompt next to the prompt type,
nvflash -b backup01.rom (This Backs up your stock BIOS, just in case you have to flash it back)
IT' ALWAYS A GOOD IDEA TO CHECK THE FLOPPY TO MAKE SURE THE BACKUP TOOK
9. Normal BIOS Flash, next to the {A:\\} prompt type,
nvflash -5 -6 1.rom This should flash it if it doesn't you force flash it.
10. Force flashing, next to the {A:\\} prompt type,
nvflash -4 -5 -6 1.rom
That's it remove the floppy and restart, DONE
Now if for any reason something went wrong you have the backup on the floppy so you just do step 9. again with
nvflash -5 -6 backup.01R flashes it back to stock.
nvFlash v5.38 Commands...
"nvflash -b backup.rom" (Backup your BIOS)
"nvflash -5 -6 1.rom" (Normal BIOS Flash)
"nvflash -4 -5 -6 1.rom" (Forced BIOS Flash)
I've never done a USB Flash but for anyone that needs info on it this might help,
Originally Posted by ChickenInferno
Okay, I have vista x64 and have been trying to do this for awhile but just couldn't. Finally, I figured out a bunch of workarounds
How to Flash Your Nvidia Bios with Vista x64 with a Flash Drive
1.)Download Winimage
2.)Download BootDisk2BootStick
3.)Download DOS 6.0
4.)Download New Bios
5.)Download NvFlash
a.) Double click on nvflash.exe to unpack the real nvflash.exe and cwsdpmi.exe
6.)Install Winimage
7.)Open Winimage and open up boot600
8.)SaveAs Floppyimage.img
a.You have to select all file types and save it like that
9.)Open BootDisk2BootStick
10.)Click the WritetoUsbFlash Tab
11.)Select the Drive Letter for your Flash Drive
12.)Click Start
13.)Select our Floppyimage.img
a.We now have a bootable flashdrive
14.)Rename the New bios to 1.rom
15.) Copy 1.rom onto Flash Drive
16.) Copy cwsdpmi.exe and nvflash.exe onto Flash Drive
17.)Boot computer from flash drive
18.) Type in nvflash -b backup01.rom
19.)Type in nvflash -4 -5 -6 1.rom
20.)Reboot, You're Finished
Originally Posted by fang_laluna
I'm using modded BIOS from this forum that allows voltage tweak up to 1.2mV I think. Right now both cards are running @ 1.125mV 870/2000 and 34596 vantage score. They were running @ 1.188mV 900/2100 for benching but crashed when I was playing BFBC2 so I use 870/2000
Yep I just downloaded nvflash 5.95 never used it before though.
So all I have to do is use Nvflash -i2 -4 -5 -6 name.rom? I want to flash the second card so in this case I need to do it separately. Why do you need USB? (sorry I really appreciate if you can explain the process a bit).
Flashing a GTX 480 using a USB flash drive
Update GTX 670-680 uses Nvflash 5.117.0.1
nvflash -4 -5 -6 name.rom works fine
http://www.techpowerup.com/downloads/2128/mirrors.php
Process, using
nvflash found on the internet
Using a USB flash drive you need
HP USB storage format tool and
win98boot found on the internet.
1st you use HP format and create a DOS startup on the USB drive then put win98boot files on it and let it format like so then hit start,
Once it's done you put the Nvflash and CWSDPMI files along with the BIOS.rom you want to flash on the USB and restart you computer and bootup on the USB, then type the commands.
EDIT: Here are a few commands,
nvflash --list (lists your cards position)
Card should be under 1 if it's SLI card 1, and card 2 or what ever the number is if anything else shows up you like your SLI controler you have to flash like this.
nvflash -i1 -4 -5 -6 name.rom that flashes card 1, If you have SLI you have to flash card
nvflash -i2 -4 -5 -6 name.rom also with a seprate flash.
nvflash -b backup.rom (Backup your BIOS)
nvflash -5 -6 name.rom (Normal BIOS Flash)
nvflash -4 -5 -6 name.rom (Forced BIOS Flash)
Have any questions PM me.
Forces
