1 - 7 of 7 Posts
Hey guys !
I bought a second hand laptop few weeks ago and noticed when on full load (games) the HD4650 goes up to 100C
I replaced the thermal paste to MX4 but still, temps are very high.
I only see high temps on the graphic card. the CPU is working fine.
Was about to buy a laptop cooler but wanted advice if it will actually help?
Some ideal temps:
CPU (T6600) - 55C
GPU (HD4650) - 65C
My cooler options are:
Thermaltake Massive23 LX LapTop Cooler
Thermaltake LifeCool Laptop Cooler
CoolerMaster NotePal X-Slim
Or i can order the CoolerMaster U2 from ebay, which will take about 2-3 weeks to get here.
An update guys.
I just got the CoolerMaster U2.
My laptop is running Guild Wars 2 for 30 min now
Temps do not pass 83C
I'm very satisfied with the results.
Thanks for your advice!
Does your laptop have a gpu fan, and if so is it fuller operational? is the heasink clogged with dust?
personally i would go with the cooler master but nzxt do a nice one too (NZXT Cryo E40)
as long as they are the same size and if want to connect them up (dont know if they need soldering etc)
1 - 7 of 7 Posts
