Originally Posted by Sco0by_568
I recently Bought the Ht-101 for my 1.8 p4 ....but theres one problem...i install everything correctly(at least i think i do) and when i turn on my pc it does not boot up but when i put the stock cooler it starts.....Can anyone help me
there might be a setting in your bios to detect your cpu fan...
and the new hsf combo prolly uses standard 4 pin molex (connector for power)
just turn off the fan detect setting and try again
the setting should be under PC health settings or something like that
hit DEL to get into your bios after you restart
if there is no setting then tr hooking up a fan to the cpu fan header and see if this works...
Lemme know if this works
