1 - 5 of 5 Posts
Mine is running at 1137mhz, is this ok, if not do i change that in the bios?
Yep, just lower it in the bios
Reactions: thedarklordjay
alright cheers dude.
Discussion Starter #4
here at 2.6ghz, im hitting 1186mhz, is that far too much, like do i need to worry?
highest you really want to go on that is 1080 1060 range. what is your HTT multi set at? mine is at 4xs. fsb= 260 multi = 10.5 which gives me 2.7ghz .... run prime95 also to see if your overclock is 100% stable, for atleast 8 hours.
1 - 5 of 5 Posts
