HTPC for my dad
499 Views 4 Replies 5 Participants Last post by  EvilGenius007
Okay so my dad wants me to build him a HTPC. His conditions are he wants the case to be a micro, and a graphics card good enough so it will be able to play Starcraft 2 and Diablo 3 (whenever those come out).
I was wondering what anyones experience is with HTPC and gaming and if I should build him two seperate machines or just one. Also what would you recommend since he is using it for more than just playing video and tv...i.e. graphics card, processor....etc.
1 - 5 of 5 Posts
We don't know what the D3 reqs will be.
So, for now, I'd recommend an AMD X2 platform with built in HD3x00/HDMI, and a PCIe slot to upgrade to whatever card is needed.
Case can't be a slim if you want to be sure you'll fit whatever card is needed for D3. I doubt a slim card will do very well with it, although we don't know for sure.
Mobo: (w/ HD4200)
http://www.newegg.com/Product/Produc...82E16813138156 - $60
CPU:
http://www.newegg.com/Product/Produc...82E16819103688 - $61
Defo go with the AM3 socket. GPU wise i think this slim gtx 260 would be great
http://www.dvhardware.net/article38117.html
case wise, not to familiar with HTPC cases but how about a mid tower case?
1 - If the PC can play games well, then by extension that means it can do most other things well too. Home users don't normally push a PC to its limits other than with games. And multimedia doesn't even come close.
2 - How much is the budget here?
3 - Guaranteeing it'll play D3 is pretty much out of the question because we don't know what the requirements will be. And SC2 will need a pretty good GPU to be able to turn up the details, so it's probably best to just wait on buying a discrete GPU until the game is released, because by then you'll get more performance for the money.
4 - This is an awesome combo deal. Phenom x2 BE and 785G for $145 AR. That's all he's going to need for a CPU, and if you're lucky you'll be able to unlock the two extra cores on it, making it a quad
5 - Does your pops have a stereo/surround system? If so he'll probably expect sound quality equal to or better than regular A/V equipment. Unless it's only being used on TV speakers, a Xonar card is a must.
Manyak has found you an awesome combo for a gaming PC. Thanks to Black Friday, it's now $139 after MIR. If your budget allows you to spend more (or less) you should check the other combo deals available with that mobo, there's a wide range of Athlon II & Phenom IIs available at discounts. I also agree with him RE: Xonar being a strong recommendation.
If you are going to be buying a video card right now, I'd check out the 40 nm Radeon HD57x0 models. They should be your best bet in terms of minimizing heat & noise while maintaining good performance. Would work great with this Antec Fusion micro ATX full-height case.
1 - 5 of 5 Posts
