1 - 6 of 6 Posts
I'm fuzzy on the whole subject of Hybrid CFX, I understand basic CFX and SLI tho. From my understanding, its Crossfiring the mobo's onboard video with a normal video card.
http://www.newegg.com/Product/Produc...82E16813157168
http://www.newegg.com/Product/Produc...82E16814131166
So could I crossfire this mobo's onboard video with this video card, and anyone have an idea if these two crossfired could run MW2 decently?
(Also, is it a giant difference between two of the same cards with different memory amounts?
http://www.newegg.com/Product/Produc...82E16814131180
The 512mb has a really good deal >.> )
Between two cards with different memory amounts, I think it only uses the lesser of the two amounts, so a 1 GB card and a 512 MB card would be treated as two 512 MB cards. That's not ideal for high resolutions.
I wouldn't bother crossfiring a 4650 with an onboard solution, but I don't know much about hybrid crossfire.
Reactions: Markisa
Thanks alot for the response, been refreshing for last 2 hours with no halp >,< the onboard memory is 128mb.. if it made the other video card only utilize 128mb of vram that'd be an issue :3
Car cheaper than computer
According to AMD the highest you can
HCFX is alot less then what you want to use.
I think it only works with the HD3xxx + HD2xxx series, I'm pretty sure last time i read up on it to see if i could do it myself and i couldn't.
1 - 6 of 6 Posts
