I had this piece of crap dehumidifier sitting in the basement. It came with the house when I bought it 4 years ago and I never really used it. I figured for its size it wouldn't have much cooling capacity but decided to check it out today. Turn out it can draw 4.8A at 120V which means it's probably a 1/2 HP compressor! It also uses good ole R22 which boils at a nice low -41c. It was made in 2009 and I thought R22 was banned by then? Must be because it's from China lol. I had nothing to lose, so I decided to disassemble the thing to see what I could do with it. It came apart with a lot of screws but not too much difficulty.
In a dehumidifier, the evaporator and condenser are back to back. This way, the evaporator can collect moisture from the air due to condensation and drop it in the tray below, while the condenser heat keeps it from freezing up and also keeps the inlet/outlet temps roughly the same (since the system is basically exchanging heat with itself). Obviously this setup wouldn't work to cool a computer. The screws connecting the two took a drill and several different sizes of philips heads to remove, since they had corroded in place. I also removed the humidity sensor that they had shoved into the evap, lol. The next challenge was to bend the evaporator to where I needed it to be, so I could dunk it in a tank of water. I had to very carefully bend the copper inlet and outlet pipes, lest I break one and lose all my precious R22. The braze joint from the outlet to the evap was particularly concerning. Luckily, I took my time and nothing broke.
I used a storage bin I had laying around as a res. It was what I had that was the right size, though not ideal. I filled it up with tap water and let it rip. It worked great, too well actually, the evaporator turned into an ice block lol. I shut it down soon after as I was worried about the expansion of water into ice damaging the evap. In a way it's good, as it verifies this system will have subzero capability. The whole bin of water stayed at 40f for hours (though it probably was somewhat cold from the tap).
I will need a coolant with a lower freezing point to test further. I'm thinking 60% propylene glycol, 40% water, which freezes at -48c. I'd like to acquire a smaller container for the evaporator (to reduce the amount of glycol I'd have to buy, and make it easier to fill/empty/move). That, and a pump/res, tubing, fittings, insulation and a waterblock that I could actually connect it to a computer with.
