1 - 5 of 5 Posts
doing research on this, i keep getting a lot of stuff on weed, dont need to know that =) but anythign else
Hydroponics Questions
What plants are grown the most using hydroponics?
Why is hydroponics used over conventional ways of growing plants?
What are some inexpensive ways that we can set up a hydroponics experiment in our classroom?
List at least 10 variables that our class could test using a hydroponics system.
What plants could we use in the classroom to experiment with, in regards to hydroponics?
Start to design an experiment for hydroponics. Remember that each group can only use one variable. With your experiment in mind, use the scientific method to help develop your experiment.
As a class, come up with the conditions that you would want to use as a control group for the hydroponics experiment.
How and what will you measure your independent variable. List 5 possibilities.
Discussion Starter #2
any info would be great im doing google but if you can find anythign else thad be great
Leafy vegetables, beans, tomatoes
The water and nutrients can be readily recycled and controlled. No dirt or land is required. In space, this is especially useful
You have to sprout the seeds using damp cloth. Then transfer the sprouts to an egg carton or a shallow dish (filled with water and a liquid nitrate food source) with cardboard to hold the sprouts.
1) Sprouting time
2) Percent of seeds that sprout
3) Quantity of light the sprouts require
4) The amount of time the sprouts need to be in the light
5) The speed in inches the sprouts grow
6) The mixture of nitrate Vs water
7) You figure out the rest
Regular bean sprouts
See the questions above and deduce the experiment yourself
See the 1-10 questions above...some of them make excellent conditions
Again, use the ten questions above to determine the answer
See my suggestions in bold
Reactions: apgfeb14
That's a lot of questions and I must admit my scientific method is a bit dusty.
Get 6 fish tanks, same amount of water. 6 thermometers
You will need a constant...I would use either type of water (distilled) or room temperature...you can even reach as far as plant type.
Hydroponics is going to depend on the mineral content in the H20 (seeding like clouds or plant food).
If you plan on having too many variables it may take a vast amount of time and resources to record all the data accurately.
See now you got me thinking all Mr. Wizard...LOL
Nice suggestions so far
Also remember you need to have a "control" sample otherwise your data will not be valid (nothing to compare it to)
Remember like overclocking, only change one variable at a time otherwise you wont know what causes the change
1 - 5 of 5 Posts
