41 - 44 of 44 Posts
Discussion Starter · #41 ·
Okay, I didn't find the original article I remember reading, but here are a few that touch on dual-core hyperthreading:
http://www.hardocp.com/article/2010/01/03/intel_westmere_32nm_clarkdale_core_i5661_review/6
http://www.anandtech.com/show/2901/12
http://alienbabeltech.com/main/?p=27571&page=7
Hyperthreading, essentially, allows a CPU core to process two threads simultaneously. Now normally this would mean a 0% performance increase, but if the two threads share resources or require identical computations, the core can get more work done. This isn't a magical process though; the game has to be specifically coded to take advantage of Hyperthreading (which is rare).
The verdict is, four physical cores will always beat a dual-core with Hyperthreading. Always. It takes some major overclocking for a dual-core to even come close to a quad-core without Hyperthreading. However, if you're building a budget gaming PC, the money saved by choosing a dual-core can be invested in a better GPU. Unless you are going CFX or SLI, or have a high-end card (GTX 680, HD 7970), a modern dual-core WON'T bottleneck your games.
Keep in mind that over 50% of gaming PCs today have dual-core CPUs. You can rest assured that any game you buy will be well optimized for two cores.
Seriously, THANK YOU so much for the several hours your no doubt spent to compile the results and write this article!!
I literally signed up on OC just to say that, though I was long overdue for that anyway.
Cheers!
MrLinky can u please guide me about HT in case of sleeping dogs game, @rig : i got 3rd gen i5-3210m processor, AMD Radeon HD 7670m 1gb, Win 7 home premium 64 bit, 4 GB RAM 1600 Mhz. I hope this info will be sufficient for telling that HT on will be helpfull or off.
Thanks
Thanks
I would just leave it on.
41 - 44 of 44 Posts
