1 - 16 of 16 Posts
Xigmatek HDT-S963
It has been the cooler ive been drooling since it came out.
A week ago, I bought it from a member here with the retention bracket and a panaflo fan.
Same day it came home, was installed and took my e2160 from 1.8ghz to 3.2ghz = 78% Overclock
The HDT-S963 came with a 92mm 68.8CFM Panaflo Fan
Temps have been acceptable.
I tought i was gonna see 69C when i overclocked.. But NO!
Have a look at these maan:
IDLE
LOAD
Load temps have never passed 60C
im happy with the cooler
EDIT:
Moar pics. 3/14/09
Are you sure those temps are correct? What's your TJ max set to in HWmonitor? The reason I ask is because I had the OCZ version which is a tad bit better than the Xig on a e2140 w 1.4v and those temps seem about 10c too low, unless you have a really cold room.
Discussion Starter · #8 ·
85 Tjunction i beleive..
In coretemp i have 85 Tjunction, and it get same temps as HWmonitor.
Hmmm, what stepping is your chip? I just find it hard to believe you get better temps with a 92mm Xig than its 120mm counterpart. Another thing that strikes me as odd is your core 0 at idle is 23c. Is your room like 15c?
When I was on air with my zalman 9500at my idle was around 22C, my ambient is around 12C right now though, I keep my window open with my computer right next to it though, now I have idle's right around 13C, gotta love water
Originally Posted by sLowEnd View Post
lol I have the same cooler
It's very quiet and gives me ok temps (Since I keep fan speeds rather low)
Mounting it was a pain though
Indeed; those plastic screws that don't screw gave me hell. I also never figured out how that spoiler sits safely
And yes, set at low speed it's very silent but stays cool as well
1 - 16 of 16 Posts
