1 - 3 of 3 Posts
I'm looking for advice on making this hard-line tube and better layout. The kit is an EK-KIT X240.
I'm looking for advice on what parts I need to get to make this a real show piece.
Tubing, angled fitting, flush, etc. This was my 1st time to do this but soft tubes are not so good :)
2488223
H₂O Aficionado
If you're into copper / nickel plated tubing, I have this old thread book marked. Might be up your alley.
Lots of info in there, including various builds with photos for inspiration.
If you can clear the gpu and if you can raise the res a bit, then here is a suggestion.
1 - 3 of 3 Posts
