TBH I wouldn't mix cards like that it will kill the PPD of your better card. So unless you are using it as a physX card I say sell it and get another 280.
Originally Posted by Tufelhunden ![]() TBH I wouldn't mix cards like that it will kill the PPD of your better card. So unless you are using it as a physX card I say sell it and get another 280. ![]() |
Originally Posted by Zippit ![]() If you want to pay for it be my guest! I'm flat broke. And yes I'm using it for a physx card and yes I want to fold on it... it still does a nice 4~5k PPD. |
Originally Posted by DIRTYDUCK ![]() I don't loose any PPD from mixing my cards. Hold on I will get you a link to the download for the multi-gpu client. its already configured to work all you have to do is change the usernames to yours....You have to use the 180.60 drivers...or thats what I use and it works great! Here it is..download that link at the bottom and unrar it then fire it up and change the username to yours! http://www.sendspace.com/file/n3ywo1 |
Originally Posted by spaceballsrules ![]() Hey DIRTYDUCK. I assume you are trying to get her the link for nafljhy's dual GPU setup, correct? My copy works wonders ![]() Here it is on OCN - http://www.overclock.net/overclock-n...2-without.html Zippit, just get the dual GPU file and follow the directions in the thread. It doesn't get any easier than that ![]() |
Originally Posted by Greg2008uk ![]() Look at this thread. I know that they would not be in SLI as you cannot fold with SLI enabled. |
