1 - 4 of 4 Posts
im not too worried about some one hacking me or anything but its just annoying is there any way other than buying a new one to reset it btw i have Linksys WRT54GL any input is appreciated thanks
There's usually a reset button on the bottom of the router, it's tiny and usually recessed in a small hole. You will lose all of your configuration when resetting, it will be back as it was when you bought it.
Press and hold the reset button on the router for 30 seconds and it will reset all the settings - its usually a pin hole that you need to use a paper clip with.
1 - 4 of 4 Posts
