i changed my mind now i am interested in 5770x2
612 Views 11 Replies 10 Participants Last post by  Nawtheph
i was thinking of getting a 2nd 4850 earlier tonight but now im interested in 2 5770s.
Is my PSU enough?
Will they fit in my case?
1 - 12 of 12 Posts
Your PSU is enough and you should have enough room in your case.
would a 5850 also fit in my case? And would that be smarter and then maybe get a 2nd one down the road?
If you can find a 5850, then that would definitely be the better choice. It is about the same performance for the same price, and you only have one card to deal with, and still have the CF option in the future. Good luck finding one though, that's why I went 5770.
The 5850 is about 9 1/2".
Honestly, with the current 58xx series shortage and inflated pricing I would opt for the 5770 CF if you really need to upgrade. I mean the price of 2x5770 is almost the price of a single 5850 and is obviously better.
Now if you can wait and stick with your current card until the 5850 falls back to it's original MSRP; then I would do that personally.
Originally Posted by dixson01974
Remember HD5770 CF = to about HD5870.
okay thats what i want to hear because its either 5770x2 now
or a 2nd 4850 now for crossfire and then a nonreference 5870 later.
Your power supply has two 6-pin connectors. It can power two 5770s, or one 5850.
Let us know how you like the 5770's. On paper the cf setup looks pretty good as far as that "bang for the buck" factor. I've got a couple on the way, don't know how long it'll take the 'egg to get them to Japan though.
1 - 12 of 12 Posts
