1 - 12 of 12 Posts
Hardware monitorWinbond W83627DHG
Voltage 01.21 Volts [0x97] (CPU VCORE)
Voltage 112.71 Volts [0xE4] (+12V)
Voltage 23.26 Volts [0xCC] (AVCC)
Voltage 33.26 Volts [0xCC] (+3.3V)
Voltage 41.08 Volts [0x87] (VIN1)
Voltage 52.59 Volts [0x6C] (+5V)
Voltage 61.61 Volts [0xC9] (VIN3)
wheres the bug?
Operating System
MS Windows 7 Ultimate 32-bit
Intel Core 2 Quad Q6600 @ 2.40GHz32 °C
Kentsfield 65nm Technology
3.3GB Dual-Channel DDR2 @ 333MHz (5-5-5-15)
FUJITSU SIEMENS MS-7379VP (CPU 1)26 °C
Graphics
W2252 @ 1680x1050
ATI Radeon HD 5800 Series
Hard Drives
488GB Seagate ST3500620AS ATA Device (SATA)29 °C
488GB Seagate ST3500620AS ATA Device (SATA)27 °C
Optical Drives
MAT****A BD-MLT SW-4583 ATA Device
BKN XEBSH2VW SCSI CdRom Device
Audio
M-Audio Delta 1010LT
Man with Fans
Originally Posted by Cronos007
Agreed, but if the readings are accurate then there is the problem. Change PSU to something reliable with enough power to run the system.
Like I said, there is no way that is reliable.
If the 5V was this low then the system would not boot at all.
Iconoclast
As Volvo has said those readings are impossible, and thus meaningless.
Anyway, performance should not change from a PSU swap.
1 - 12 of 12 Posts
