1 - 12 of 12 Posts
I know that title sounds stupid... And right now I fill stupid. I have been running my system for about a week at 3.2 (8x400) Everything was stable 4 hours on prime, just running sweet. Tonight I was playing Halo on line when all of a sudden it crashes , memory dump and reboot. (1GHzx4 G Skill 4-4-4-12 1:1 by the way) I was running voltage conservative so I figured on reboot I would just up the volts a little to 1.38.
Well this is what I find (sww attachment) when I reboot and it is not running as good as it was, low 16s in PI and I was getting that when I new it was 3.2!
[/URL][/IMG]
Some programs (and Windows, afaik) like to use the default multiplier for your chip at all times, regardless of the fact that you've apparently lowered it to 8 (from 9). Its running at whatever you've got it set in the BIOS, and as long as you know what it's set at, and at least one reputable program recognizes it, its all good.
Try running Memtest86+ and see if it comes back with any errors. Chances are with the ram that heavily OC'd, a small power fluctuation could have caused the ram to act funky temporarily. You never know.
Power Squid
Seeing as you've lowered the multipleir some programs will display you clock speed as if you haven't. This is a glitch with certain Intel motherboards, though you can trust the latest version of CPU-Z to always show the actual clock speed.
Reactions: Thedev
Exactly.
Discussion Starter · #11 ·
memtest showed no problems.
Well it wanted a multiplier of 9 so I am going to give it one! 3.6.is better then 3.2 right?
Temps are good and I havent had time completlely check stablity but so far so good. I know this is not the place but does anyone have any suggestios on volts?
Thanks guys for the help, I really appreciate it!
PI 1m 14.2 I really like that ALOT!
Power Squid
Like I said before, some programs wont recognize the correct multiplier if you lower it from within the BIOS on certain motherboards.
You were running 400FSB @ x8 = 3.2Ghz
But your programs thought it was at x9
400FSB x9 = 3.6Ghz
To run my E6600 at 400FSB on the x9 multiplier (3.6Ghz) I had to use 1.55v CPU vCore, 1.55v MCH (NorthBridge) vCore and 1.55v VTT voltage. Seeing as you're useing an Intel Chipset based board you'll prbably have to raise FSB termination voltage a little as your board doesn't have VTT.
I hope you find that info useful.
1 - 12 of 12 Posts
