1 - 16 of 16 Posts
Simply, it's a program that downloads and analyses the way proteins fold and misfold and sends it back to Stanford U. By analysing the way they fold and misfold, cures for genetical diseases can be found, so it's great to be help
So basically, download the program and run it for as long as you can
Discussion Starter #5
How the fudger sickle doe sit do that?
Simulation. it simulates how a protien folds, and how it could misfold.
Discussion Starter #7
Ok i did it hwo do i get tha tlil thing to show up?
what do you mean? i don't understand your question.
Discussion Starter #9
The little red gear that says I fold for overclock.net under the avatar area and liek hwo do i get on the team page?
Discussion Starter #11
Originally Posted by ThE_GeNeRaL
you have to complete a WU
a WU i ghot 52 days for that damn well is that 52 days of having it or it being working?
Discussion Starter #13
Originally Posted by thehacker11
upp wait till it does a couple frames cause same with mine mine said 8 days now it says 1 day 10 hrs
lol ok kool
Yep, the GROMACS core for example is one the most complex cores and take a long time to analyse. The cores that are appointed to you are selected by your CPU speed (if you got a fast CPU it'll give you a bigger core, if you have a slow CPU, it'll give you a smaller core).
1 - 16 of 16 Posts
