I fried my board
1109 Views 23 Replies 8 Participants Last post by  kairi_zeroblade
sig rig. I was following this guy's advice second post
I was using the cpu overvoltage setting as my main volt changer, then read that, so switched to cpu vid as my main one. I set it to 1.35 (the max for that setting), then used overvoltage to get it to 1.45, then--Boom! board is dead:swearing: at the old settings, I had my voltage up to 1.5 and all was well
I cleared cmos, but nothing happens when I push power.
any necromancers out there with suggestions? I read once about using foil to bring a dead board back...how do I do that?
1 - 20 of 24 Posts
I thought so, I'm gonna test my psu tomorrow...hopefully that's not it, cause I got the 2 year extended warranty on my board...I just don't wanna use it after only 2 months.
was that guy's advice bad?(on the AMD forum)
I had it up to 1.55 with my method, and then it died @ 1.45? it doesn't make sense
Did you do a hard CMOS reset? that is, unplug the PSU, pull the battery, hit the power button a couple of times. That is the only way to completely clear the CMOS. Sometimes just using the jumper won't do it.
you should have the "Instinct" and awareness of what you are gonna do..so far his advice works only on his way..you should know better since you are the one who picked your parts..
^true that^
Instinct and awareness? It made complete sense to me--set it at 1.35(the max for my board) then I overvolted it to 1.45-which I had it at before--and it failed....
....maybe an explanation of those particular settings would enlighten me. (cpu vid-vcore, right? and cpu overvoltage)
yeah I picked my parts, but not the bios layout--I've never had a board with "overvoltage" before
I'm not here to be scolded, I'm here to learn
yup we all are here for the same reason too..but its always a reminder to do such thing with awareness so far as you have said its always been 1.35 volts for your assumption..trying 1.45v ASAP is a nono you should have tried raising it a step at a time..like 1.362 then if all goes well another one to 1.37..til you fine tune that setting giving it a single blow will end up just like that..i think what i am trying to tell you is its always a step at a time to reach your goal..
we all learn through our mistakes and its the best teacher for me so far..in your case i advise you that when you engage yourself to something new like this i get to know my parts well before i do some "serious" tweaking..its just like getting to know your best friend..
no, you misunderstand. I've had the board at 1.55 with no problems at all. It was at 1.12ish cpu vid, and because I didn't understand some of the bios settings, overvolted to 1.55 on accident. this was a few weeks ago, and it booted fine-no problems. then I put the overvolt to equal 1.35 and it's been fine ever since
this time I set the cpu vid to 1.35 (stock settings) then upped the overvoltage to equal 1.45 cause I new it could handle it--well, I thought it could...why did it take 1.55 back then and now it couldn't handle 1.45?
I think it's just a bad board
I feel your pain, my original motherboard died after 2 days on my 1st build, not from overclocking though. Sucks to have $200 of hardware become useless.
If you can I'd suggest trying another psu, maybe even diff. ram/proccessor. Good luck!
i'm not that paul guy, lol--I found that through google
my idle temps were around 36 @ stock, and 40 @ 1.41 volts-even @ 3.5 GHz , before I changed the way I set up my voltage---everything was fine until I messed with the cpu vid instead of the "overvoltage" setting
i see..so you've been there at 1.55v..maybe your board can't seem to handle that much voltage..if its the CPU VID then maybe your chip got roasted either way isolate the mobo and chip..i have a bad feeling that the chip is the culprit..
newt111.... what was your Core VID set at before you changed it? And what exactly did it do after you had?
I got an am2 chip to test, backup ram, and a psu tester....will try all tomorrow....I hope it's the board, cause I got the warranty...
I really hope you're wrong about the chip- I lapped it and can't return it
it was set at 1.125 I believe, then I set it at 1.35(the max for my bios)
then set the overvoltage setting to + .1 to equal 1.45--rebooted, then utter failure:swearing:
damn..OMG
it really is a serious case indeed..subscribed!!
hope to hear results dude...
Try clearing the CMOS overnight....
yessir
then Imma testing those other parts
Looks like your board just died on you. 1.45v is nowhere near the amount to kill a 940.
I'd also try a different PSU, just in case. It would make a little more sense.
system status:
board--fried (tried my other CPU and still won't boot)
PSU--fine
Ram--fine
CPU--dunno until I get my RMA back
I'm RMAing this, and will put it my HTPC.
I'm gonna get a GIGABYTE GA-MA790X-UD4 for my gaming rig instead
1 - 20 of 24 Posts
