I got another Antec Three Hundred!
1766 Views 8 Replies 6 Participants Last post by  noobst3R
After looking at some cool case mods over the last couple months, I figured that I need to try some. If I don't have a project or something I am bored anyway lol. So, I got the 300 from amazon for $50. I didn't really want to mod the only case I have... Well, actually I don't know how I would do that. I would be computer-less. What do you guys think?
1 - 9 of 9 Posts
congrats on getting another antec 300 case
cable management holes in the mobo, a hole in the bottom of the case so you can flip the PSU over, paint it black, add more fans.
You can check out my build log in my sig if you want.
It seems like shopping online when I'm tired always benefits me
But here are my plans:
-Cable holes
-3 140 holes cut on top
-large clear side window
-case feet
-paint inside
-Maybe put brushed aluminum vinyl on the panels and then put carbon fiber vinyl on the front plastic
Those are just some of my ideas. I may never actually get them done...
-Cable holes
-case feet
-paint inside
Sounds great, good luck!
As far as mods go, this is what mine use to look like before I got my Hd5770 (which is in the mail....)
Hey, i'm getting an Antec 300 as well pretty soon, any cool case mods to do with it? I currently have some cold cathodes and 2 extra Scythe fans for it, but i was thinking about installing a window, is it possible? I hope there are some pretty good mods (Without being a pro construction worker
You can install a window on any case. MNPCTech has some tutorials you can watch!
http://www.mnpctech.com/CaseModTutorials.html
1 - 9 of 9 Posts
