1 - 3 of 3 Posts
What ever happen to the days of building PCs was easy :p . So I'm in the process of doing a new H20 build and need some advise. In my current configuration - DeepCool Genome, I'm struggling with putting 2x 1080 Ti's in there due to space. So with this new build, I'm looking for something larger yet has some good airflow. I plan on water cooling the CPU and GPUs. I do like an open case concept, but I have not seen anything that supports 2 GPUS. The 2 cases so far that I like are the Thermaltake Core P90 (only supports 1 GPU that I've seen) and the h440 designed by razer - nzxt. But I feel that the NZXT is the same size and the Genome and will be snug. Thanks
Not a Linux Lobbyist
i had two 970's in a h440 with no issues.. apart from it's poor airflow
it's really not a case that lends itself to decent watercooling IMHO
pretty much any enthusiast grade atx case will take sli and adequate watercooling
im also fairly confident you can get sli on one of the thermaltake open cases. the vertical gpu bracket carries multiple slots, obviously you'd need several riser cables... or you can just mount them traditionally
1 - 3 of 3 Posts
