I currently have a Define R5, but its too big to be mounted under my table in the clamp, as its very wide, therefore I consider swapping to a Define C, but is there other cases I should consider?
I have 3 140mm Noctua fans and a D15, so need to be wide enough for that (It just fits in the Define C)
Pluses:
Airflow
Noise dampening
Minuses
Tempered glass
LEDs
The Define C is 21cm while my R5 is 23cm
Pluses:
Airflow
Noise dampening
Minuses
Tempered glass
LEDs
