1 - 11 of 11 Posts
i have a computer with 3.0 ghz CPU(LGA775) i have an stock CPU fan(AVC p4424NC)
a stock case fan and a stock GPU fan
when i play NF2 my CPU temp 50-60C
and i have ATI Radeon X550 overclocked (both core and RAM)
my cpu and memory are not overclocked.
i think i need some fans so i looked and found this:
http://www.newegg.com/Product/Produc...82E16835150057 CPU
http://www.newegg.com/Product/Produc...82E16811999612 case
http://www.newegg.com/Product/Produc...82E16835118212 GPU(i dont know if the size is ok for the grahphic card?)
and may be a hard drive cooler.
is this going to be ok with the temp???
ok that cpu cooler isnt going to be much better than stock (if any!) the case fan u can get and the gpu cooler isnt much of an impovement either...u should look for something with heatpipes for your cpu,and for the gpu look for an arctic cooling kit for it, and invest in some arctic silver 5 too.
Discussion Starter #4
howdo i do the thing with system spec to be under my post ?
by the way i dot have any fans on the northbrige chipset and should i get RAM heat spreaders for my ati X550??
go to 'usercp', its at the top of the web page under the overclock.net logo, and go to edit system specs and fill it out withh all the info u know about your comp.
Discussion Starter #6
can some one put some links for cheap and good fans (CPU,GPU,case,northbride) and is there a way to overclock the processor that i have non of the program are compitable with my motherboard,and the memory?
are you looking for a just fan or a heat sink w/fan? These are what will cool the best,and if u plan on overclocking your cpu anytime these will be necissary...
1 - 11 of 11 Posts
