1 - 3 of 3 Posts
I have a pc with i3 9350KF 4GHz with turbo 4.6GHz and i have a MSI H310M M.2 Pro 8gb ddr4 2400mhz ram Asus GTX 1650 OC
i have recently checked that my processor is bottlenecking gpu also my processor is unlocked also i bought a Gamaxx 400 v2 cpu cooler
i want to overclock it at any cost without spending money
there must be any way to do so like bios flashing or anything
if ram is causing bottleneck pls guide me to overclock it too
i also overclocked gpu before some days with 1500+ on mem clock and 200+ on core clock found stable
Old to Overclock.net
Sorry, the H310 has no overclocking features. You need a Z series board to overclock. Look to see if you can find a cheap Z370 (make sure it has an updated bios) or Z390.
^this
Make sure multi-core enhancement is enabled in BIOS (if you have it) to maintain all core 4.6ghz boost. I very much doubt you're bottlenecking your gpu much with that processor though; there is maybe 5% more performance left on the table?
Ultimately I think you should be looking at a completely new PC package if you are after more performance.
1 - 3 of 3 Posts
