I have a problem
279 6
I cannot connect to the work server to get a work packet, can someone please help?
1 - 7 of 7 Posts
Can you get to the internet with IE?
If you can, make sure you check the box that says "Use Internet Explorer settings to access the internet"
The only other explanation would be that the server you are trying to reach is down...which happens occasionally.
Have you previously been able to download WUs, or is this a new installation?
maybe try a reinstall... and are u using the screensaver version or the reg. version?
1 - 7 of 7 Posts
