I have a spare fan, Put it on my radiator?
495 Views 6 Replies 4 Participants Last post by  shredzy
Currently I have 3 fans on the roof of my Cosmos S like this :
Should I put it on the radiator from inside the case pushing? Would it harm cooling as it will be 1 fan pushing and 3 fans pulling?
1 - 7 of 7 Posts
hmmm
i would say switch it entirely
make 3 of them pushing, and then make the1 you have over pulling...
That's how I set mine up actually. Had air pushing from outside -> to radiator -> inside case. Just so I can get the cool air from outside the case, I didn't do it the other way around cause I believe your gonna be pulling heat from the gfx card etc through the radiator.
Problem I have is that I can't get 3 fans on the inside of my case because the VRM cooler on the top of my motherboard is quite large and blocks the 3rd fan from being install.
I meant I installed my fans where you are showing them in your pic. Ontop, not inside the case.
whta you mean??? do you mean you cant get 3 fans fit inside case??
I mean how hes showing his fans in that pic is where I installed them. On top of the grill.
1 - 7 of 7 Posts
